March 18th, 2015, 01:03 PM | #1 |
Join Date: Mar 2015 Motorcycle(s): 08 Ninja 250r Posts: 6
Cush Drive Questions
Just got new sprockets for my 2008 Ninja 250r. I had them replaced at a shop and after I came to pick it up the worker told me that my cush drive rubbers need to be replaced. Is the guy bullshitting me?
Any advice will be greatly appreciated. |
March 18th, 2015, 01:11 PM | #2 |
dirty boy
MOTM - Apr '14
he could be, but not sure why unless they plan to really stick it to you with parts and labor costs. They are just rubber inserts, the bike is an 08, and a 250 at that so it is not like they see a ton of instant torque to beat them up. I guess they could dry rot? Take a look for yourself. Either way don't pay them for jack unless it is next to free, can get used rubberz off ebay for a few bucks and it is easy to do yourself replacing them. Most difficult thing about the whole process is setting chain tension and axle alignment when finished and that isn't exactly difficult.
note there is typically a little play in the cush drive regardless of good rubbers or not, perhaps this guy is unaware of that and thinks it should be tighter? Did he say what was wrong with it?
March 18th, 2015, 01:15 PM | #3 |
Are the ones on ebay worth buying if they are used themselves? Can you not buy them new?
March 18th, 2015, 01:31 PM | #4 |
I'm crazy,your excuse is?
You can shim the cush drives, basically they pull off the wheel with the sprocket still on, you can add shims as needed- some have made shims with milk bottles, just stuff them on the sides of the wheel/cush drive. If you got to the faq there is a procedure- how to.
March 18th, 2015, 02:09 PM | #5 |
just shim them up and you'll be fine.
March 18th, 2015, 02:14 PM | #6 |
^^^ this
When you go to shim them up, snap a pic and post it. If they are in terrible shape (rot, rips, and such) or missing one(s), you will need new or good shaped used ones.
March 18th, 2015, 02:56 PM | #8 |
Fighting Texas Aggie '05
I wish someone would make some nice urethane inserts to replace the cush rubbers.
March 18th, 2015, 02:59 PM | #9 |
You can get a set for a Busa for like $50, wish they were more available for other bikes
March 18th, 2015, 04:26 PM | #10 | |
https://www.ninjette.org/forums/showthread.php?t=114612
March 18th, 2015, 05:09 PM | #11 |
you could always pour your own using the stock parts as a mold... wouldn't even have to worry about release agents since its already in its final position
March 18th, 2015, 07:50 PM | #12 |
I want to mess around and pop wheelies. Wont that cause excessive wear and tear on the rubbers? So would it be safer to purchase less used ones then to shim them?
Also what do yous think about theses? http://www.ebay.com/itm/08-12-Ninja-...b92c5b&vxp=mtr |
March 18th, 2015, 09:45 PM | #13 |
Track Clown
MOTM - Sep '15
if i needed to replace my cush drive $11 would work along with some cut up credit cards to shim the drive.
Drive Lash and the Cush drive | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 20 | November 19th, 2014 01:55 PM |
Cush Drive Shim | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 24 | June 30th, 2012 12:51 PM |
WTB: 08+ Sprocket Carrier and Cush Drive | SNAPPY | Items Wanted | 0 | April 4th, 2012 08:37 PM |
Cush Drive Replacement | jorgecornet | Videos | 11 | May 26th, 2010 08:27 AM |
Technical: Cush Drive on 2008 Ex250R | Sailariel | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 25th, 2009 05:24 PM |
