Old April 28th, 2016, 05:53 PM   #1
Spencerrides
Motorcycle(s): 2005 Kawasaki Ninja Ex
Motorcycle Rev/Idle Problem
Hey you guys always do a excellent job of knowing what's wrong with my bike and how to fix it so I'm hoping y'all know what to do with this problem.
When I'm riding it every time I give it throttle it revs up then the revs go Down alittle than it just stays at a certain high rev.
Any ideas?
Sometimes it will slowly go down.
example: I'm riding I give it some throttle release the throttle but the bikes revs don't go down.
Last futzed with by Spencerrides; May 1st, 2016 at 06:40 AM.
Spencerrides is offline   Reply With Quote
Old April 28th, 2016, 07:10 PM   #2
Originally Posted by Spencerrides View Post
When I'm riding it every time I give it throttle it revs up then the revs go Down a little than it just stays at a certain high rev.
..... Any ideas?
It seems to me that the clutch is slipping some.
What oil have you been using?
Does your clutch lever has a 2 mm gap prior to pulling the cable?
Does it do it more when the engine is hot than when it is cold?
Old April 28th, 2016, 07:20 PM   #3
Spencerrides
I Just bought the bike I'm not sure what type of oil.
Clutch Lever:I'm not sure
When it's hot it does it .
Could "slipping the clutch" this happen from incorrect revmatch downshifting ?
Old April 28th, 2016, 07:25 PM   #4
Spencerrides
When I down shift I...
1.Close throttle
2.pull in clutch
3.shift down
4.Give throttle
5.Slowly release clutch
Old April 28th, 2016, 08:48 PM   #5
........ Could "slipping the clutch" this happen from incorrect revmatch downshifting ?
No, if the clutch works correctly, there is solid connection between the engine and the gear box any time that the clutch lever is not pulled (clutch-in).
If the speed marked by the speedometer remains constant and the rpm's marked by the tachometer fluctuate, there is some slippage among the discs of the clutch.
That slippage is not good because it overheats the oil that lubricates the engine, weaken the clutch's springs and can distort the steel discs of the clutch, creating other problems.
Please, check these links out:
http://faq.ninja250.org/wiki/Lubing_the_cables
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
http://faq.ninja250.org/wiki/Preferred_Brands
http://faq.ninja250.org/wiki/How_do_...ping_clutch%3F
The simplest thing to check is that there is absolutely no pressure on the lever that is located at the top of the clutch cover when clutch is not applied: it should have a little but noticeable slack of the cable.
If not, two things may be happening: the cable is not lubricated and/or the adjustment of the lever at the handlebar is incorrect.
Old April 29th, 2016, 06:19 AM   #6
ducatiman
ducatiman's Avatar
sticking carb slides?
insufficient throttle cable freeplay?
throttle mechanism or cable(s) need clean/lube?
internal carb issue?
fuel delivery problem...starvation causing lean condition?
You've got some homework to do....
bike at rest, key off ...open throttle fully...release...does throttle snap back on its own? ALL the way back to closed?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 29th, 2016, 06:45 AM   #7
Spencerrides
Dang I didn't know bikes were high maintenance ,
I'm going to make a video today.
Yea the throttle snapped back in place
But the bike this morning isn't acting up at all.
It's usually starts to happen after I ride it for a really long time.
Could it be from overheating?
Old April 29th, 2016, 07:10 AM   #8
Spencerrides
I'm making a video but it only happens when I ride the bike for a really long time.
Could this be from overheating?
Old April 29th, 2016, 07:22 AM   #9
Ghostt
Ghostt's Avatar
Tank vent issue?
violente et ignorantia
ZX-2R BLOG
Old April 29th, 2016, 09:37 AM   #10
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
You just got the bike. I would do a oil and filter change first, along with what already stated.
My Cafe Racer Build
My intro post
Old April 29th, 2016, 09:41 AM   #11
Spencerrides
A 05 Ninja problem on Video
Here is the video showing the problem.
I Apologize for my last thread it was kind of confusing.
Hopefully this shows the problem a lot clearer.
Happens after riding the bike for a while.
Please respond thank you.
https://youtu.be/L5RhZuAEO98
My apologies about last thread.
Old April 29th, 2016, 09:42 AM   #12
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
No video?
Goin' fast on slow bikes!
Old April 29th, 2016, 09:46 AM   #13
allanoue
allanoue's Avatar
MOTM - Sep '14
Old April 29th, 2016, 09:47 AM   #14
Tick, tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick tick, tick, tick, tick
Have your valves adjusted my good man... it's time. Odd though, bike has less than 7k on the clock.
Hmmmm.... valves are still possible, but the more i hear that sound, the more it sounds like the cam chain or really crappy oil. Hard to tell... :\
EDIT: You sound like a smart fellow. I am assuming the oil is at proper level and not contaminated with anything? Gas maybe? Here is my thought, if you have a carb issue that is causing your bike to rev like that, then possibly the gas is overflowing into the oil. Check that out before you ride again, your right... it aint good for your bike.
Old April 29th, 2016, 09:48 AM   #15
Brother Michigan
It's not a clutch issue (if I understand what you've typed and it's that revs hang with a closed throttle, not that revs drop with constant throttle), so the places to look at throttle and fuel/air.
I don't know if this is diagnostically relevant, but if you blip the throttle a few times when the revs start to hang, does that help the problem at all or do they just continue to hang? Also, approximately what RPM does it hang at when you're experiencing the issue?
DISCLAIMER: I generally have no idea what I'm talking about.
Old April 29th, 2016, 10:05 AM   #16
allanoue
allanoue's Avatar
MOTM - Sep '14
@Alex
does this
https://www.ninjette.org/forums/show....php?p=1099986
/merge
Old April 29th, 2016, 10:12 AM   #17
ducatiman
ducatiman's Avatar
badly out of synch carbs or throttle plate(s) hanging up?
Potentially dangerous....make sure your kill switch operates correctly if/when riding....up until you get the carbs inspected and serviced, valves checked, oil changed as was suggested by cs smith above.
Custom Carb Service
Old April 29th, 2016, 10:13 AM   #18
Spencerrides
Possibility of contaminated gasoline, I used a used portable gas tank to fill it up with unleaded 87 gasoline.
The portable gas tank I used was not used for like a year so any liquid I figured would have been evaporated... so I thought would leave minimum contamination.
I also filled about 7/8 to the top
Just checked the oil gauge when I checked it from a standing upright position the oil was filled completely, also the oil seemed darker than usual.
Old April 29th, 2016, 10:36 AM   #19
xorbe
xorbe's Avatar
Air leak around the boot area?
Old April 29th, 2016, 11:20 AM   #20
MyTriggaz
Motorcycle(s): 01 Ninja 250
Have you been messing with the idle screw a lot? Maybe close it up all the way and start from zero and get your idle set?
MyTriggaz is offline   Reply With Quote
Old April 29th, 2016, 11:21 AM   #21
I would say you could use a valve adjustment, carb cleaning, and carb sync.
The reason it goes to 4000 after making the idle speed adjustment is because you turned it a bunch. Turn it a little, give it a quick rev, then check it again. Turning it 3 turns will make it idle at 4000.
Idle mixture screws are probably set too lean. Be sure to remove the caps and set them at 2 turns out. If there's any question about the gas, save yourself a lot of headache and drain it. Refill with fresh gas and get the engine warm before making any adjustments.
Old April 29th, 2016, 12:08 PM   #22
Brother Michigan
This is what I noticed as well. After turning the idle adjustment knob, give the bike just a little bit of gas to let it settle at the newly-set idle RPM. The idle speed when move a little on its own when you're trying to raise it, but it needs some gas to get up to its new "happy place". Also, make small adjustments; it looks like you gave it a good two full turns from where you started (in total, not just after you turned the idle down by accident), which is a lot. Try it about a quarter turn at a time.
I'd go ahead and get your idle speed set to somewhere between 1200 and 1500 RPM (or whatever you prefer, but that seems to be the norm) and see if you can replicate the problem you described earlier. If this IS the problem you described earlier, then it looks like it's an easy fix!
Old April 29th, 2016, 01:15 PM   #23
Spencerrides
Hey guys on my carburetor there's a big hole on of the sides should their be a hose in that spot because I have 2 long hoses hanging down and 2 short ones hanging down is that normal?
Old April 29th, 2016, 01:18 PM   #24
Hard to say.
Here's a bunch of photos of the ninja's carbs that may help - http://faq.ninja250.org/wiki/Carburetor_photos
Old April 29th, 2016, 02:31 PM   #25
xorbe
xorbe's Avatar
Post pics. If you can't for some reason (less than 10 posts etc), drop them on imgur and post the image IDs.
Old April 29th, 2016, 03:33 PM   #26
Spencerrides
Are these hoses in the correct position ?
@xorbe @jkv45
Old April 29th, 2016, 09:23 PM   #27
xorbe
xorbe's Avatar
Just sold my N250 + manuals, but the 3rd pic, I think that's the air box drain / or removed smog equipment. Someone else has to chime in on the carb.
Old April 30th, 2016, 05:22 AM   #28
ducatiman
ducatiman's Avatar
Yes, the plugged hose is airbox drain.
The big hole is a "welsh" plug. Its a permanently plugged factory port....no touchee, and no hoses attach to it.
The carb body "holes" are engineered and manufactured for the fuel paths, vents and throttle shafts. Keihin (the carb manufacturer) then installs needed inner components and caps the access holes off, which is what you are pointing at.
Intricate little buggers, aren't they?
Custom Carb Service
Old April 30th, 2016, 07:30 AM   #29
Spencerrides
Ahhh Okay Thank you, what about the hose to the right of the plugged Factory Port? Is that hose not supposed to be connected to anything?
Old April 30th, 2016, 07:37 AM   #30
Spencerrides
@ducatiman @xorbe
How mechanically Inclined do you have to be fix a problem like this ?
Or should I just take it to Mechanic?
Any Idea how expensive it would be for a mechanic to look at?
What would be the maximum cost to get it fixed?
Old April 30th, 2016, 07:40 AM   #31
Spencerrides
Yea I been messing with the Idle Screw a lot?
I Also accidently rode my bike with the choke Half way on one day by accident that same day it started giving me this issue.
Old April 30th, 2016, 07:45 AM   #32
allanoue
allanoue's Avatar
MOTM - Sep '14
Spencer I don't think there's anything wrong with your motorcycle. Did you do what brother Michigan said here? Forgetting to turn off your choke is common it's not good for your gas mileage but it's not going to hurt much.
Old April 30th, 2016, 07:49 AM   #33
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I agree with this.
Adjusting the idle screw a lot doesn't always immediately take, until you blip the throttle.
Small turns, blip. Small turn, blip. Get it set to just under the 1500 RPM mark.
See if the issue persists.
Old April 30th, 2016, 07:54 AM   #34
ducatiman
ducatiman's Avatar
did a retake on your video-- I concur you are making too radical a change too quickly to the idle....from one extreme to the other.
obviously, choke is ok to get started when cold/cool but gradually, slowly ease off it as soon as engine is able to idle
You want around 1200-1300 RPM *bike fully warmed*. Slowly adjust...up or down to achieve this.
Then....warmed, idling smoothly at that RPM...IF there is any hanging up when throttling and releasing...a further problem exists.
Try it...see what you get.
Custom Carb Service
Old April 30th, 2016, 07:56 AM   #35
Spencerrides
@allanoue @RacinNinja
I'll Give it a go, will let know if problem still occurs
Old April 30th, 2016, 08:16 AM   #36
allanoue
allanoue's Avatar
MOTM - Sep '14
@ducatiman @xorbe
If you still have an issue, read the DYIs here how to clean and adjust your bike, they are good and you can do it. If you think not, PM ducatiman, he will do a better job then your local guy for less.
Old April 30th, 2016, 10:00 AM   #37
ducatiman
ducatiman's Avatar
^ thank you allan......and *yes i can*, correct on both counts
Custom Carb Service
Old May 1st, 2016, 06:05 AM   #38
Spencerrides
Guys Please forgive how ignorant I am when it comes to motorcycles.
I Was adjusting the idle before the bike completely warmed up thinking it was running to low but when heated up it skyrocketed.
Yesterday I reset the idle screw completely and adjusted it now it working correctly... I think
When I stop accelerating or at stop sign it will idle at like 2000 for several seconds then eventually drop to 1300-1100.
Will keep updating
Old May 1st, 2016, 06:14 AM   #39
ducatiman
ducatiman's Avatar
Will keep updating
define "eventually"
Custom Carb Service
Old May 1st, 2016, 06:25 AM   #40
allanoue
allanoue's Avatar
MOTM - Sep '14
Nothing to forgive. I am very happy we were able to help you save a trip to the shop as well as lurkers with the same issues. They should thank you for posting.
2010 Ninja 250EX wyciwug 2008 - 2012 Ninja 250R Tech Talk 5 October 6th, 2013 12:06 PM
