Old August 26th, 2013, 03:05 PM   #1
jackliu239
Motorcycle(s): 2006 Ninja 250R
Slow acceleration speed after 40mph
I just got this 2006 Ninja 250, so far it only have less than 250 miles on it, I only rode for about 100 miles after the purchase, and this is my first motorcycle. One thing I notice recently is that I can accelerate the bike to 40 mph no problem around the 3-4 gear.
But going from 40mph to 50 is very very hard. Even after I twist the throttle all the way in around the 4th gear, the RPM still goes up very slowly from 6-8, I sometimes have to downshift 1 gears for the RPM to go up to 7-8, then up shift again, but even with all of this. So far I still have not gone more than 50 mph yet. I'm sure if I will eventually get it up to 60+ mph, but I feel like that is going to take a long time to happen.
I don't even want to think how can I ever go to freeways, it will take so long for me to accelerate to 60, I'll be a road hazard.
I am a new rider, so is this normal for 250? And does it have to do with the fact that the bike's engine is still in the break-in period?
Also another thing I notice but might be unrelated, after the RPM goes to more than 7, the sound the engine makes is a bit different, yes it's louder, but I feel like it's a bit more than that, I can't describe it, but the pitch of the sound is much higher as well as the noise level. So when I hear that I always shift gear, I'm afraid it will damage the engine or something.
Last futzed with by jackliu239; August 26th, 2013 at 08:42 PM.
jackliu239 is offline   Reply With Quote
Old August 26th, 2013, 03:22 PM   #2
DaBlue1
DaBlue1's Avatar
Other than ride it, what have you checked?
Have you checked the air filter?
What size sprockets are on the bike?
What condition are the spark plugs in?
At what RPM speed do you normally shift gears? 40-50 mph should be very easy to reach in 3rd or 4th gear.
Old August 26th, 2013, 03:28 PM   #3
KawiKid860
KawiKid860's Avatar
06 with 2500 miles could be gummed up carbs
Old August 26th, 2013, 03:32 PM   #4
jackliu239
I have not check air filters, the sprocket are original factory size, I have check the spark plugs, they are good. I normally shift gears at 5-6.
Old August 26th, 2013, 03:33 PM   #5
jackliu239
Sorry, that was a typo, it has less than 250, not 2500 miles on it.
Old August 26th, 2013, 03:40 PM   #6
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Carbs probably need cleaned. Try shifting at 12k rpm's.
Old August 26th, 2013, 03:41 PM   #7
nokfir2
nokfir2's Avatar
even worse.
that means it was ridden average 35 miles a year. this bike has done alot of sitting around. def clean those carbs...
also....ninja 250's arn't that fast anyway
nokfir2 is offline   Reply With Quote
Old August 26th, 2013, 03:46 PM   #8
jackliu239
Oh the carbs are completely cleaned, when I first got it the engine won't even start without cleaning the carbs.
I'm just curious around RPM do you guys shift? For me, it seems I always shift at around 5-6k RPM which is very easy to get for from 1-40 MPH, but after the 3rd or 4th gear after I shift, the RPM meter stays at 5-6k, and it takes a much longer time to go up to 7-8K as well as speed going up.
But I do get the feeling that I should shift the prior gears at much higher RPM and well as my current gear?
Old August 26th, 2013, 03:47 PM   #9
jackliu239
Originally Posted by nokfir2 View Post
even worse.
Well, not average of 35 miles a year... more like 100 miles during the first month, and 0 miles for the rest of the 6 years
Old August 26th, 2013, 03:49 PM   #10
jackliu239
For example, when I'm at 5th gear at around 4-5k RPM, no matter how much gas I give it, the speed won't increase at all.
This is normal right? Because I changed gear too early?
Old August 26th, 2013, 03:54 PM   #11
KawiKid860
KawiKid860's Avatar
You need to rev a 250. On bigger bikes those speeds+rpms are fine, but the 250 doesn't have anywhere near the power of something larger
Old August 26th, 2013, 04:31 PM   #12
This is very important.
After 7 years of storage that filter needs oil, ..........if that foam didn't disintegrate itself by now.
If the inbox is free, the next thing to check is any restriction to the supply of fuel.
Old August 26th, 2013, 06:25 PM   #13
SDx
Motorcycle(s): 02 ex250, 07 HD xl1200n, 69 ct90
I shift at around 8k when commuting and somewhere between 9k and 11k when out in the hills
SDx is offline   Reply With Quote
Old August 26th, 2013, 06:31 PM   #14
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
When I had my 250, I don't think I was ever below 5,000 not even when going slow. I'd shift typically around 8,000-9,000.
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old August 26th, 2013, 06:31 PM   #15
quarterliter
Motorcycle(s): 2004 Ninja 250
Make sure the bike is warm before your shifting at these high rpm. Touch the case on the right side. If it is too hot to hold your hand on it then your good to rev it. But stay under 5k when the bike is cold. Take a few warm up laps around the subdivision or something before having to go anywhere. Rotella 15w40 for a cheap good oil and a wix filter. Change it every 2000 miles tops. Its cheap easy and a good thing to do. Oil the airfilter and run ethanol free gas. I got my bike with 250 miles on it too. Carb cleaning and oil change etc later, it runs like a champ.
Old August 26th, 2013, 08:11 PM   #16
jackliu239
Thanks, great advice. Maybe just one more question, I find my bike is really slow to warm up, sometimes I need to open the choke partially for up to a few minutes otherwise the engine just shuts off on me. I assume this is because the engine is not hot enough right?
Or is my fuel tank have water inside of it? Because I left the bike at friend's place for 2 days, I found out that his sprinkler system turns on every morning for about 15 minutes and my bike is all wet because of it, I'm just afraid that there might be water drops gather at the top of the fuel tank and leaking inside. So is there anyway to check if you have water in your fuel tank?
Old August 26th, 2013, 08:50 PM   #17
jackliu239
Also during the warm up process, the engine won't start with full choke on, unless I give it a bit of gas to start.
What I have to do is that, press the start button, I would hear this put-put-put then it quickly dies out. UNLESS at the same time of starting the put-put-put I give it throttle then immediately the engine would start come online and jumps to about 4-5k RPM (I can let go of throttle and it still runs) it stays there until the engine fully warms up, (this is with choke on btw), but if I ever put off the choke in the process of warming up, the engine would dies right away.
I'm not worried about turning off choke and engine dies during warm up, I heard this is normal.
But is the other part normal? The one that immediate after the engine starts I have to give it gas to make it from dying out (once I give it gas to start, the engine can keep going with no problem).
With everything else being said, the bike runs excellent (I think).
Old August 27th, 2013, 05:51 AM   #18
agentbad
agentbad's Avatar
Try putting some seafoam in the gas tank and see if that helps the carbs. If it's warm out you shouldn't really need to use the choke.
Old August 27th, 2013, 06:41 AM   #19
You're not going to go anywhere on a 250 Ninja if you don't rev it to where the power is. The older Pre Gen Ninjas need to be near 10,000 to really get rolling. There's not much power or torque available at 5000 or 6000.
Change the oil and filter if you haven't already, check the basic maintenance items, and let 'er rip. Don't hesitate to go to 10,000 or beyond if you need to (once it's at operating temp - as Quarterliter noted).
If you want a 250 that doesn't need to rev to that range you need to look at the CBR250R. The 250 single isn't a screamer like the Ninja's twin.
As long as you do the proper maintenance and use decent oil (and keep track of the oil level), the high revs aren't a problem.
Here's a comparison of 250 power curves. The Ninja curve is the later model than yours, and actually makes its power lower, but you can see why you need to spin pretty high to get to the power.
Old August 27th, 2013, 07:10 AM   #20
DaBlue1
DaBlue1's Avatar
.... I find my bike is really slow to warm up, sometimes I need to open the choke partially for up to a few minutes otherwise the engine just shuts off on me. I assume this is because the engine is not hot enough right?
....Also during the warm up process, the engine won't start with full choke on, unless I give it a bit of gas to start.
Sounds like your idle speed may be too low. Once the bike is fully warmed, set the idle speed @ 1500 rpms and see how it does. Also add some Star Tron Fuel Treatment and some fresh 87 octane gas to your tank.
Old August 27th, 2013, 07:42 AM   #21
Chuffmonkey
Chuffmonkey's Avatar
Motorcycle(s): 2012 Triumph Street Triple R, 2011 250R SE (sold 5/8/13)
I'm not sure that your original question was answered definitively - this is not normal. This sounds nothing like an issue with you not being in the powerband, and everything like poor ignition.
Can you define slowly - how many seconds does it take to accelerate from 40 to 50?
If you're on the flat and go WOT there should be absolutely no need to have to downshift to accelerate - my (admittedly newgen) Ninja had enough pull in top gear to get me from 40 to 50 without requiring a downshift.
As was mentioned you need to check airflow, spark and fueling - any of these can cause a power loss.
As for needing the choke to start, my Ninja always needed the choke, no matter what the ambient temperature was - and I often had to give it gas right away. I would treat these as 2 separate issues and worry about the poor acceleration first - but again, please define "slowly" for us.
Chuffmonkey is offline   Reply With Quote
Old August 27th, 2013, 10:24 AM   #22
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I believe that your choke is messed up, I had the same issue but with a boat and it was the choke not opening.Take a look at the choke cable and its operation. If the choke is on at high speed, the motor is getting too much fuel.
My Cafe Racer Build
My intro post
Old August 27th, 2013, 10:30 AM   #23
jackliu239
I think the slow acceleration is my driving problem, I was at 4th or 5th gear at 4-5k rpm and it won't go fast no matter how much gas I give it, but today, I tried to shift only at near 6-7k RPM and I see some very big improvements. So far I have not yet gone faster than 50 mph yet, and I think if I only shift around 7k rpm it shouldn't be a problem.
What I am more concerned is potential water in my fuel tank, my bike was soaked from my friend's water sprinkler system. Does anyone know if Ninja's fueling port have some kind of seal? Preventing water from leaking inside when it's fully closed?
Old August 27th, 2013, 10:34 AM   #24
jackliu239
Would be, when I try to cold start, it will only start with choke all the way on, and I have to give it a bit of gas from engine dying out, and once the engine starts with full choke on, it immediately jumps to 5-6k RPM.
I need to keep this for at least 1 minute, during this 1 minute, any lowering of the choke will kill the engine, but after 1 minutes or a bit more, I can try to lower the choke a bit and it might go down to 4k rpm, but if I'm not carefully, if I accidentally lower the choke too much the engine dies as well.
Old August 27th, 2013, 10:35 AM   #25
jackliu239
Once the bike is fully warmed and in operation, the idle speed is actually just around 1.5k RPM. The bike runs great after 10 minutes or so, it's just the first few minutes gets my all worried every time I start it up.
Old August 27th, 2013, 10:38 AM   #26
jackliu239
Thanks for the tip, I didn't know that. This is my first motorcycle, when I drove my car I never let the RPM go more than 3k acceleration or starting. Everything was so smooth lol, I'm just afraid that rev the engine too hard will make my Ninja explode, but I know now this is not the case.
Old August 27th, 2013, 10:55 AM   #27
n4mwd
n4mwd's Avatar
When you cleaned your carbs, did you clean the pilot jets as well? A lot of people miss those.
Here is what normal acceleration on an unmodified Ninja 250 is like:
FYI: If you lean forward, you can avoid accidental wheelies.
My Ninja Blog
Old August 27th, 2013, 11:02 AM   #28
.......when I try to cold start, it will only start with choke all the way on, and I have to give it a bit of gas from engine dying out, and once the engine starts with full choke on, it immediately jumps to 5-6k RPM...........
Those high rpm are hurting your cold engine.
Lubricate your choke mechanism and cable to be able to fine adjust the rpms' at start up never higher than 3K.
Please read this:
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
What about that neglected poor air filter?
Old August 27th, 2013, 01:16 PM   #29
quarterliter
immediatly jumps to 5-6k
Old August 27th, 2013, 01:25 PM   #30
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
That's what it will do with the choke fully on.
Old August 27th, 2013, 01:31 PM   #31
jackliu239
Please read this:
Thanks, that's good advice, I'll check air filer as well as choke line.
I'll try the best method to perfecting my warm up process. I got to say, motorcycles requires A LOT more hands on attention than my SUV lol. So is all carbrated bike like this? Are fuel injection bikes like CBR250 don't need to warm up?
Old August 27th, 2013, 01:52 PM   #32
They don't need any input from the rider during warm-up. The F.I. system reads the engine temp, air temp, etc and enrichens the mixture just enough to maintain a slightly high idle for only as long as necessary.
The choke isn't that big of a deal. Once you get it figured out you won't think about it.
Old August 27th, 2013, 04:42 PM   #33
n4mwd
n4mwd's Avatar
The choke control is touchy, but you can get it to idle at 3K RPM with a little practice.
Nevertheless, it still sounds like your carbs aren't right.
My Ninja Blog
Old August 27th, 2013, 07:00 PM   #34
jackliu239
The carb has been stripped and clean to the very last detail, includes the jets.
I may have figure out the problem, when I open the seat cover, I can see 3 rubber tube supplying oxygen going to the crab (I think), one of the tube is bend in the middle, for example, have you ever tried to wash your car at your own drive way, then suddenly the water flow stops or became very slow, then you figure out that the hose rubber tube is twisted onto it self and water flow became a problem. It is exactly like that for one rubber line, and there is no way to straighten it, because I think it has been bend for so long, the rubber has became fatigue and permanently bend out of shape.
Old August 27th, 2013, 07:12 PM   #35
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
There are two very good points that have been previously mentioned, and until you check them, you are not going to be able to diagnose the problem correctly.
1. Is your Air Filter clean?
2. Did you clean the pilot jet when you cleaned the carbs?
- These are hard to get to and pretty much invisible when installed.
Edit, you replied as i was typing this message
The_big_dill is offline   Reply With Quote
Old August 27th, 2013, 07:14 PM   #36
The_big_dill
Which hose is it? Can you take a picture?
Old August 27th, 2013, 07:22 PM   #37
DaBlue1
DaBlue1's Avatar
.... I can see 3 rubber tube supplying oxygen going to the crab (I think), one of the tube is bend in the middle,
You may be referring to CA. Emission hoses on the tank. Instead of venting the tank directly to the air, gas fumes are contained in a closed system (if it's still installed on the bike.)
The middle hose is just a vent hose and connects to nothing. The hoses on the left and right connect to a canister.
Old August 27th, 2013, 07:23 PM   #38
jackliu239
It is the far right one, the previous owner must have lock it under the seating locking mechanism and put it like that for many years, now the hose is permanently bend somewhere in the middle. Do you know what does that hose connect to?
Old August 27th, 2013, 07:28 PM   #39
jackliu239
I don't know if the filter is clear or not, I took it out and it looks clean enough, I even use my vacuum machine to vacuum on it a bit as well as use my compressor to blow air on it quite a bit, some dust come off it, but not that much.
Both pilot jet was clogged, they have to use the needle and wire to clean it very carefully, now it's cleaned, before it was not cleaned the bike won't even start at all.
At this point I have to wait until tomorrow to start the bike to see any difference, because I want it to cool down to the air temperature first, I will also see if there is anything I can do to the hose to strengthen it a bit.
Old August 28th, 2013, 05:56 AM   #40
n4mwd
n4mwd's Avatar
California Emissions
This might help a little:
But it doesn't look like any of this stuff would interfere with the engine that bad. It connects to the overflow line of the carb and another spot connects to the airbox. There is nothing standing out that would actually interfere with the running of the bike that I can see.
My Ninja Blog
Idleing too high and slow acceleration problem Arkangel1200 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2015 05:26 PM
Giving up the slow bike for a slow car CycleCam303 Off-Topic 17 February 18th, 2014 02:13 AM
Slow throttle response and slow return to idle help Crriiissss 1986 - 2007 Ninja 250R Tech Talk 22 August 7th, 2013 12:26 AM
Woot! I can't sleep just thinking about it haha itsmeanuj New Members 19 April 21st, 2011 06:00 AM
[superbikeplanet.com] - And Miles To Go Before I Sleep Ninjette Newsbot Motorcycling News 0 January 7th, 2010 01:50 PM
