September 28th, 2013, 05:46 PM | #1 |
Join Date: Jul 2013 Motorcycle(s): 2007 Ninja 250r Posts: 128
School Me: accelerating corners, setting up
So, my ninjette is stock, save Kenda 657 Challenger rear, and Pirelli MT75 front [both suggested sizes in NinjaWiki]. Reading through your Riding Skill threads, I've begun atacking corners [mild in your eyes, im sure; but way better than Ive done before.]
I'm wondering where I'm chickening out, basically. My back tire has much contact surface and feels very secure in clean corners, its just that feeling of 'maybe I'm too low' that causes me to lift slightly. I've taken corners around 10mph faster on average now that I've instilled into my riding the lack of 'Target Fixation' and keeping my arms bent, and leaning my head in towards my handlebar. I push my butocks back to the edge of the seat before it goes flat, shift onto that inner thigh right past the crease between ass and leg, and seem to pull the bike into turns. It feels great; if only I had some sort of gopro or similar device to show you guys. Reading your riding skill threads has inspired me, but given me a cautionary failsafe at the same time; I know I'm not as good of a rider as 90pct of you, and I dare not push what I think are limits. I have no tracks in Edmond to practice on, and I'm afraid Oklahoma cops would ffffff me if I played in a parking lot. I guess I'm looking for a post that'd show me the light in terms of how exactly I should be taking these corners; we don't have many twisties here, just long easy turns . Unless youre in a neighborhood, the turn shouldn't be under 20mph. I'm trying to figure out what the max speed to tilt I can achieve is, without risking dumping my baby. So if this post makes sense, lecture me pls. |
September 29th, 2013, 01:10 AM | #2 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
If you only have long easy turns then you can probably safely turn as fast as your ninjette will go without so much as having to move your bum around on the seat.
I'd go in search of some some nicer roads if I were you. Preferably with corners that you can see right through so you know there's nothing there before you hit the corner. I have a lot of fun cornering on roundabouts (which there are plenty of over here!). |
September 29th, 2013, 09:13 AM | #3 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
On and off ramps... Shoot the clover
September 29th, 2013, 10:17 AM | #4 |
MOTM - Mar '13, Jun '14
Ride for 10,000 miles first. Then ask questions on how to be a faster, better rider. Most of it will come naturally with those 10,000 miles.
September 29th, 2013, 11:20 AM | #5 |
Could you explain your question a little more for me, Josh?
September 29th, 2013, 03:16 PM | #6 |
Lol. You risk dumping your baby every time you ride it. No lean required.
That said, track riding will let you easily hit 40-45 degrees lean until you drag hard parts. I guess the biggest limiting factor in how far you lean/how fast you turn/how likely you are to crash while doing so is that big sack of flesh connecting your handlebars to your seat and foot pegs. |
September 29th, 2013, 06:41 PM | #7 |
Well, what I was geting at was, is there a known equation, based on a constant weight of rider, which shows the speed to tilt of the bike, to the degree/angle turn taken, under perfect riding conditions [0-3mph winds, ideal heat to asphalt, with touring/track tire]? I figured with all the studies out there, someone might have stumbled on a gem. Some sort of line graph, or pictures with equations? /shrug
September 29th, 2013, 07:56 PM | #8 | |
That angle compensates for the lateral force that appears each time that you abandon a rectilinear trajectory. That lateral force depends on the square of the speed and the inverse of the radius of the turn. Take a look at these: http://www.ninjette.org/forums/showthread.php?t=100964 http://www.ninjette.org/forums/showthread.php?t=138226 http://www.ninjette.org/forums/showthread.php?t=119958 http://www.ninjette.org/forums/showthread.php?t=98085
September 30th, 2013, 10:25 AM | #9 | |
Join Date: Aug 2011 Motorcycle(s): 2012 Ninja 250, 2008 Daytona 675 Posts: 212
1. Perfect riding conditions do not exist in real world. Pavement temperature varies throughout the day. Cracks/sealer/imperfections in the pavement will affect the grip. Small pebble will affect grip. Your hand input will affect your bike in turn. How are you planning to monitor the lean? You don't exactly have an indicator on the bike and if you do why are you looking at it? (Ex: Many track riders tape up their speedo. It's useless information located in a completely wrong place) 2. You LEARN to take your bike to the extreme. Even if I told you that your tire can easily take 45 deg lean, can you actually ride to take advantage of that? Yes, you might, but if you're new then you'll be hanging on for dear life and not actually relaxing and planning your next corner. The way you learn is you learn to lean the bike to 30 deg first, then 40, then 45 then 60. Progressive improvement, not 0 to hero, 'cause that tends to end in just 0. 3. This isn't MotoGP. Last futzed with by RedOctober; September 30th, 2013 at 11:37 AM. |
September 30th, 2013, 11:50 AM | #10 |
I understand all these factors, Red. I simply asked for the data, should it be handy.
Thanks for the post, Motofool. I'll begin studying. |
September 30th, 2013, 12:52 PM | #11 |
I'm crazy,your excuse is?
If you have to ask,you cant afford it.
Ona serious note, only time on the seat will allow you to push it more and more and become confrotable and more proficient. I am taking really slow... |
September 30th, 2013, 01:26 PM | #12 |
September 30th, 2013, 01:54 PM | #13 | |
September 30th, 2013, 02:59 PM | #14 |
join a gymkhana club
September 30th, 2013, 04:16 PM | #15 |
I know what I posted wasn't exactly what you wanted. But fact is, your not gunna learn to corner via text on a screen. Sure you can get some theories and such but you just gotta get out there and put them to to work with a watchful eye or at least the right mindset. Anything else can work yes, just takes longer.
If you want to start learning off with a proven method, start with counter steering (slowly!!!), them move to throttle control, and then visual skills. Until you have a confident grasp on those concepts and applications, you will be slowing yourself down in your learning. Where do you currently stand with those?
October 1st, 2013, 05:00 AM | #16 | |
5. Perceived lean angle may not, and probably won't, be anything close to actual lean angle.
October 1st, 2013, 05:23 AM | #17 |
You are welcome, Josh
Great, feel free to ask more questions, as those concepts may be confusing. In summary, it is simply Physics of balanced forces applied to any turning two-wheel machine, being the rider's mind the weakest and least predictable of those forces.
October 1st, 2013, 12:03 PM | #18 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
On an nsr when I'm dragging both a boot and knee puck is about that time I decide I'm leaned over as far as I can. Apparently you low side after pushing it any harder than that...
October 2nd, 2013, 03:34 AM | #19 | |
October 2nd, 2013, 05:33 AM | #20 |
Yeah, but that's not a measurement of specific angle, just a gauge to tell you when you're about to go too far. Løckøut was asking about specific speeds/angles in one of the posts above.
October 2nd, 2013, 12:38 PM | #21 |
King Hamfist
I was just adding some very light humor. Not to be mean but some of the concepts in here are a little ridiculous. Go race a motorcycle. When you're constantly finishing on the podium ask yourself why and everything will make sense. p
Clunking while accelerating | MrAtom | 1986 - 2007 Ninja 250R Tech Talk | 40 | March 10th, 2015 06:02 AM |
Power hesitation when accelerating? | mrb | 2008 - 2012 Ninja 250R Tech Talk | 17 | December 5th, 2013 02:35 PM |
Strange Noise when Accelerating w/Video | SDx | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 7th, 2013 10:34 AM |
Bogs down when accelerating, max 5-7k RPM | Jeffro2749 | 1986 - 2007 Ninja 250R Tech Talk | 17 | August 25th, 2013 09:03 AM |
power loss while accelerating hard | redbike | 2008 - 2012 Ninja 250R Tech Talk | 32 | June 28th, 2010 05:00 PM |
