Old October 1st, 2014, 05:58 AM   #1
Manimal
Manimal's Avatar
Motorcycle(s): 2013 Ninja 300 SE
Slip-on: Exhaust Popping?
As some of you may know, I had recently acquired a 300, used. It came with a Yosh slip-on already mounted. Any how, when rolling off the throttle, I hear an occasional popping ...... something similar and very common when upgrading the exhaust on the new gen 250; which required jetting or shimming, and or removing some emission plumbing.
Anyone know a fix for this?
Manimal is offline   Reply With Quote
Old October 1st, 2014, 06:14 AM   #2
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Flux capacitor
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old October 1st, 2014, 06:23 AM   #3
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
You know.... some companies go through extra trouble to have their vehicles pop on deceleration. Ever hear an F-Type?
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old October 1st, 2014, 06:40 AM   #4
Hero Danny
Inline 4!!!
Hero Danny's Avatar
The popping I believe is because the exhaust makes your bike too lean. Only way to fix it would be a power commander to adjust the fueling map.
On a side note: I like the popping sound, especially when deceleration, my mussari did that... I really need to get a slip on for my 300.
Be careful. Remember you are
invisible
Old October 1st, 2014, 06:52 AM   #5
BlownWideOpen
I like the popping too, I removed my KLEEN air system on my bike and thought it'd kill it. But now it's crazier than ever, sounds like a banshee.
Old October 1st, 2014, 06:52 AM   #6
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
I love the popping. Used to happen on my 250 with the 2 bros slip-on and my mustang pops pretty regularly.
Definitely think it's a bit funny that so many people strive for it and you're trying to get rid of it.
My vlogging channel: Ma1iciousLogic
Malicious Logic is offline   Reply With Quote
Old October 1st, 2014, 06:53 AM   #7
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Mine does it all the time (i have a two brothers slip-on). Feather the clutch a bit as you roll off the throttle and it stops. Not sure if there is a true 100% "fix" for it. I don't mind it myself, its not hurting anything i know of.
If it dose not have a power commander i would highly recommend getting one and mapping it for your pipe.
Raven's Rejuvenation
Old October 1st, 2014, 07:02 AM   #8
mania
mania's Avatar
Motorcycle(s): 2013 250
Actually all bikes pop but with the stock exhaust so heavily baffled you do not hear it.
Even if you put in a power commander/dynojet etc. EFI controller you will likely still have some popping on deceleration because the lack of baffling will let you hear it.
But.....If you want to decrease it to almost unnoticeable just close the throttle all the way when decelerating.
Try it you will see how well it works.
most dont realize they have it slightly cracked open even when they decelerate & think they are off throttle.
Just try it as it is easier done than explained. You will see a big improvement/reduction in popping
mania is offline   Reply With Quote
Old October 1st, 2014, 07:14 AM   #9
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Old October 1st, 2014, 10:16 AM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
popping can be a symptom of an exhaust leak.
check all exhaust gaskets, joints in the pipe, ect...
Old October 1st, 2014, 11:04 AM   #11
when you close the butterfly valve it chokes on air. extra fuel goes past and doesn't burn and hits the hot exhaust pipe where there is a tiny bit of left over oxygen (compared to inside the cylinder where there is none left) and has a very small backfire. normally you don't hear it because of the heavy baffling in the stock exhausts. the extra fuel going through actually helps cool the valves when engine braking.
Old October 1st, 2014, 04:03 PM   #12
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
My exhaust sounded like 💩 till I changed to a high flow air filter... Probly not your issue, just on topic
Old October 1st, 2014, 04:06 PM   #13
JohnnyBravo
The fuel moto is better
Old October 1st, 2014, 04:38 PM   #14
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I had popping with the stock exhaust and I still have popping now with an aftermarket full exhaust with PCV. It amuses me so I don't worry about it *shrug*
My Ninja 300
Old October 1st, 2014, 06:39 PM   #15
JohnnyBravo
I don't think I've ever heard a bike that didn't pop in one way or another... Just wait till your bike shoots flames out the pipe
Old October 2nd, 2014, 08:11 AM   #16
Manimal
Manimal's Avatar
Originally Posted by BlownWideOpen View Post
Flux capacitor
Only if I wanna sh*t myself anytime I wanna crack the throttle above 55+mph ..... lol
Thanks for the responses and insight as to why. FWIW, I have read posts that for a slip-on, an ECU change is not necessary. Any case, seems more common than not. Honestly, it doesn't bother or really concern me. And yes, it does add some additional character from the pipe, aside from the throaty rumble.
Old October 2nd, 2014, 08:26 AM   #17
BlownWideOpen
Thanks for the responses and insight as to why. FWIW, I have read another posts that for a slip-on, an ECU change is not necessary. Any case, seems more common than not. Honestly, it doesn't bother or really concern me. And yes, it does add some additional character from the pipe, aside from the throaty rumble.
Throaty rumble? Sounds like... never mind.
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
Popping noise out the exhaust Kviper52 1986 - 2007 Ninja 250R Tech Talk 1 October 6th, 2011 07:07 AM
new akrapovic slip on.. popping/backfiring questions ninjaflav 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2011 07:04 PM
How much popping? (and exhaust leak) singlecoillover 2008 - 2012 Ninja 250R Tech Talk 30 May 30th, 2011 08:35 PM
My bike kept sputtering, exhaust made a popping sound, first gear barely moves? Bostonninjabastard 2008 - 2012 Ninja 250R Tech Talk 6 May 11th, 2010 06:21 AM
