Old January 5th, 2015, 06:05 AM   #6281
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Originally Posted by NevadaWolf View Post
Lessons learned: When reinstalling the front cowling, it is vital to plug the headlight back in. And when reinstalling the side fairing, the same holds true for the front turn signals.
Oops!
Raven's Rejuvenation
Old January 6th, 2015, 09:15 AM   #6282
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
It (my ninja) continued to be not worked on.
Old January 10th, 2015, 10:50 AM   #6283
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Michelin Pilot Street Radial rear tire on its way to replace my really squared off rear tire. Also, Revzilla is ****ing awesome. Ordered yesterday. Should be here today and I only used their free ground shipping
My Ninja 300
Old January 10th, 2015, 06:07 PM   #6284
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Reached 62k. The little Ninja that could. *chug-chug-chug*
<-- Linky
4 out of 4 members found this post helpful.
Old January 10th, 2015, 08:10 PM   #6285
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Swapped battery tender from K75 to Ninjette.
Old January 12th, 2015, 11:10 PM   #6286
tfkrocks
tfkrocks's Avatar
Cleaned the air filter. Was a bit overdue. Oops.
Also I realized that I hadn't been very good at keeping service records. I had missed writing down the last couple tire changes and couldn't remember if I had ever changed the spark plugs. Just searched and I did in fact change them and posted about it here. Apparently I keep better service records on this thread
My Ninja 300
Old January 13th, 2015, 08:52 AM   #6287
NevadaWolf
NevadaWolf's Avatar
I thought that's what this thread was for.
LOL
<-- Linky
Old January 13th, 2015, 09:32 AM   #6288
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
looked up her dress!
hey shes under a cover right now sleeping...
My Cafe Racer Build
My intro post
Old January 29th, 2015, 12:47 PM   #6289
NevadaWolf
NevadaWolf's Avatar
Let's see, been posting in the "latest pick up" thread vs here for parts and bits.
Installed the handguards
And just bought some new pegs/mounts
<-- Linky
Old January 31st, 2015, 08:23 PM   #6290
shereth
shereth's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250
7500 mile maintenance! Was a little intimidated at the prospect of tearing it open and checking the valves but thanks to the helpful DIY's on this site it was .. well, maybe not quite a breeze, but no big deal either. Got lucky and everything is still in spec so no adjustments necessary.
shereth is offline   Reply With Quote
Old February 1st, 2015, 07:51 PM   #6291
cuong-nutz
cuong-nutz's Avatar
Finally got around to spending some money on the bike: carb rebuild kit and finally fork springs after 5 years.
HalfFast Racing Team
Old February 1st, 2015, 09:54 PM   #6292
ninjunk
Lostcause enthusiast
Motorcycle(s): 2000 EX250F
Got her running!
Bolted on rebuilt carbs
Changed oil filter and cleaned filter screen.
T6 rotella
Checked valves and plugs, good.
Bent foot pegs and mufflers into place and fixed shifter.
Took a bit of cranking to light off but once she cleared out she was purring like a kitten. Haven't even synched carbs yet. Took her all the way up to temp and sounds good, all lights work gauges and everything.
Took about five hours two of which were wasted fighting with the air box boots which were hard as hell and I had to boil them to soften up enough to install.
ninjunk is offline   Reply With Quote
Old February 4th, 2015, 06:27 PM   #6293
cuong-nutz
cuong-nutz's Avatar
Good job Graham!
Well I finally had some time to rebuild the carbs. I was having starting issues since it got cold. It would take a while of cranking for it to fire up. I would hear it backfire in the muffler trying to start and then finally it would. Also, oil was contaminated with fuel.
I pulled the carbs off and noticed right away that the idle mixture screws were set wrong! they were poking out of the body! Resetted them to 2.5 turns and 2.75 turns respectively. For those that have not figured it out, the idle mixture screw turns are not equal.
Next off, one of the float needles had worn grooves to cause it to stick slightly. Hopefully this what's causing fuel to seep into the oil. Need to replace the rubber caps on the vacuum nipples since they're dry rotting too fast. I need to switch to the plastic ones.
Rejetted to Dynojet 96 jets from DJ 98s since I swapped back to the stock exhaust header and can. They're the equivalent of stock Keihin 98 jets. Hoping for better than 150 miles to the tank!
Old February 6th, 2015, 04:52 PM   #6294
TreyL
TreyL's Avatar
Motorcycle(s): EX250J
I removed my garbage chain and got ready for mid 70's weather tomorrow.
TreyL is offline   Reply With Quote
Old February 7th, 2015, 12:47 AM   #6295
NevadaWolf
NevadaWolf's Avatar
Installed the new pegs, topped off the oil and coolant, repaired some busted accessory wiring, and repainted my rims. Ready for the new year!
<-- Linky
Old February 7th, 2015, 06:30 AM   #6296
sparky80
Motorcycle(s): 2007 Yamaha FZ1, 2006 Yamaha FJR1300A, 2014 Ninja 300
cleaned her all up and ready to sell.
2006 Yamaha FJR1300
And, my 2007 Yamaha FZ1. My favorite bike ever.
sparky80 is offline   Reply With Quote
Old February 7th, 2015, 08:52 AM   #6297
NevadaWolf
NevadaWolf's Avatar
Ohh shiney.
Sticking with the FZ1 or going for something new?
<-- Linky
Old February 7th, 2015, 09:11 AM   #6298
sparky80
Sticking with the FZ. I realized that I like the little bike but have probably gotten too used to the power of the Yamaha too much.
It's just not for me.
2006 Yamaha FJR1300
Old February 7th, 2015, 09:42 AM   #6299
Suki2003
Ninjette Lurker
Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected)
been working on cleaning the piston seals and replacing the pads. Had trouble bleeding the front line. Just finished that this morning. Lever is hard...mmm...
time to wait until the roads aren't salty to wear in the pads and ride again....
Suki2003 is offline   Reply With Quote
Old February 7th, 2015, 12:47 PM   #6300
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
It's a shame I'm not out enjoying the weather, but pizza and beer is callin my name...
Romeo peed on baby shreks tire though
Old February 7th, 2015, 08:32 PM   #6301
Ghostt
Ghostt's Avatar
Should have been working on mine, fixing my small problem
but it was a great day to do nothing, but to enjoy the weather.
violente et ignorantia
ZX-2R BLOG
Old February 8th, 2015, 09:44 AM   #6302
Unloaded the bikes from the trailer and back to the garage.
Old February 8th, 2015, 10:15 AM   #6303
JohnnyBravo
I have heard almost enough motorcycles to drag me out of bed, just Gota wait till the church traffic gets settled an I may go for a jaunt.
Old February 8th, 2015, 10:40 AM   #6304
Skullz
Skullz's Avatar
Uncovered the bike with wet and snow cleared roads at 39* and went for a ride, amazing what some MMO in the gas tank has done for the gas over the last few weeks of sitting, started and purred instantly instead of turning over for a bit before firing up.
MMO = Marvel Mystery Oil
Old February 8th, 2015, 04:31 PM   #6305
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Nothing .... but I did go ride the 6R for about and hour and a half.
Old February 9th, 2015, 01:10 AM   #6306
Daks
Jersey Devil
Daks's Avatar
Motorcycle(s): '06 Ninja 250
Cleaned/lubed chain, installed some formerly fallen out fairing bolts.
~Riding like a grandma because I wanna ride as a grandma~
Daks is offline   Reply With Quote
Old February 9th, 2015, 02:33 AM   #6307
JohnnyBravo
Had a pretty sweet ride
That marvelous mystery oil is some good stuff !!!
Old February 11th, 2015, 02:09 PM   #6308
astricklin
Motorcycle(s): 08 Ninja 250
last weekend, charged battery, changed oil, and got her fired up. cleaned and lubed the chain. ordered brake pads and new braided line for the front. those will arrive today and go on this coming weekend.
astricklin is offline   Reply With Quote
Old February 11th, 2015, 02:16 PM   #6309
Ghostt
Ghostt's Avatar
Don't forget to disassemble and clean the caliper, and flush, and filled with new brake fluid.
ZX-2R BLOG
Old February 11th, 2015, 06:08 PM   #6310
liquidnine
Motorcycle(s): 2005 Ninja 250
Replaced the clutch cable that gave way today on my way to lunch. Replaced the petcock too, since it would flow fuel without a vacuum.
Last weekend had front springs, sprockets and chain put on. I did the rear shock and chaon guard. Made little tank panels too (to hide the bolt holes)
liquidnine is offline   Reply With Quote
Old February 13th, 2015, 04:29 PM   #6311
cuong-nutz
cuong-nutz's Avatar
Fork Springs are the second best mod you can do for the bike with tires being the first. Oddly for me, I just finally got around to replacing mine just now after owning the bike all these years.
Old February 13th, 2015, 08:10 PM   #6312
liquidnine
The suspension upgrades have been great. My rear wheel would be in the air and spin up at with even moderate bumps. The bike feels much more stable now and still feels comfortable to ride.
New mufflers were today's addition!
Old February 14th, 2015, 09:32 PM   #6313
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Got her finished up in time for a valentine's day ride!!! Ooooooommyyyygodddddd..she's a whole different animal now! I should have my write up posted by tonight..we'll see lol.
The Bike | The Truck
Old February 16th, 2015, 04:31 PM   #6314
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Got my new tires on (Michelin Pilot Street Radials), oil changed and the chain lubed and cleaned. Wow, what a difference in tires from the stock IRC's. I just rode it around the block for a quick jaunt and you can definitely tell how sticky they are in comparison.
antiant is offline   Reply With Quote
Old February 16th, 2015, 04:36 PM   #6315
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Yeah those are nice, just wait til you ride in the rain on those. It's amazing to feel the same grip in the rain that you do in the dry. They feel almost as good as the Q3s that I have on my gsxr in terms of grip, they'll last a hell of a lot longer though
Old February 16th, 2015, 06:48 PM   #6316
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Yeah, I was going to be the type of rider who didn't ride in the rain, but I did it on the IRC's. I think I'll have way more confidence in the rain with these PSR's. It's all about pace and going slow in different types of conditions. I got to get the proper gear for rain though.
Old February 16th, 2015, 06:54 PM   #6317
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
What mufflers are those??
"That's what" -she
Roark is offline   Reply With Quote
Old February 17th, 2015, 02:16 PM   #6318
Ghostt
Ghostt's Avatar
I made an icicle....... Get it?
ZX-2R BLOG
Old February 17th, 2015, 02:18 PM   #6319
allanoue
allanoue's Avatar
MOTM - Sep '14
That cat does not look too happy about the snow
Old February 17th, 2015, 04:47 PM   #6320
Ghostt
Ghostt's Avatar
O trust me, she's just fine being an outdoor cat, and she's spoiled rotten And her brother too.
Yes their both in their insulated home, and wool blanket too.
ZX-2R BLOG
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
