Old March 27th, 2015, 06:11 PM   #81
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
I believe... Rum and coke is good... Whys the rum gone???
Raven's Rejuvenation
Old March 27th, 2015, 06:14 PM   #82
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I believe I have the same relationship with red bull that capt. jack sparrow has with rum
Old March 27th, 2015, 06:18 PM   #83
i believe i can fly... i just can't afford it
Old March 27th, 2015, 06:42 PM   #84
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Originally Posted by crazymadbastard View Post
I believe that my slow is slower than your slow!
I believe I can out-old, out-bald and out-slow you any day of the week. Punk.
Old March 27th, 2015, 06:42 PM   #85
4 out of 4 members found this post helpful.
Old March 27th, 2015, 06:44 PM   #86
adouglas
adouglas's Avatar
and speakin' of ramen noodles.
I believe... aint nobody knows how to really cook with ramen noodles unless you been to da big house. hahahahahahha Did you know... noodles are a form of currency in prison?
lol
I believe @csmith12 has a past he hasn't told us about.
Old March 27th, 2015, 07:06 PM   #87
on the real though, legit ramen is like a ****in art form.
Old March 27th, 2015, 07:12 PM   #88
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I believe my parents did some batshit crazy **** when they were my age that they will never tell me about or admit to
Old March 27th, 2015, 10:39 PM   #89
corksil
Motorcycle(s): A lot.
I believe that the neighbors might have thought they just heard a few gunshots.
I believe that it makes me smile when the three 55gal drums - each partially full of different types of race fuel - outside my window each contract due to the temperature dropping in the evening and each of the three partially full drums let out a very loud metallic popping sound as the air gap within the drums contracts causing the air-tight drums to let off a very loud metallic clang.
I believe this makes me smile because when each of the drums emit their evening gong within several minutes of eachother, it means that each of the three 'race' vehicles are seeing equal use and consuming their fuel at an equal rate.
BANG! Bike.... CLANG! Truck.... TUNK! Racecar.
I believe that living in america has it's perks.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old March 28th, 2015, 03:57 AM   #90
adouglas
adouglas's Avatar
I believe alex.s dropped the "I believe" ball
Old March 28th, 2015, 10:24 AM   #91
corksil
I believe alex.s does indeed have a point.
Old March 28th, 2015, 12:45 PM   #92
DSomething
DSomething's Avatar
Motorcycle(s): 2015 Ninja 300 ABS
I believe that de-sanding a vagina is probably pretty darn painful.
I believe I cannot imagine how one would get themselves into a situation when they would need a de-sanding.
I believe it will take me a long time to get this out of my consciousness.
I believe I need a cigarette (but, by no means, a de-sanding).
D.
(And that does not stand for de-........., I just can't say it anymore)
DSomething is offline   Reply With Quote
Old March 28th, 2015, 02:44 PM   #93
I believe that pounding wheel bearings out of these bikes is a giant pain in the shorts. But I believe it's making me feel better to hit things after I've broken tools all day. HULK SMASH!
Old March 28th, 2015, 02:50 PM   #94
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I believe.... I need a nap
I believe ... I am sleepy... But not grumpy, maybe sneeze
I believe ... My pillow needs replaced
Old March 28th, 2015, 02:54 PM   #95
i have a little blind bearing puller that has a slide hammer on it. you stick it in and spread the claws to push the bearing out the initial mm or so and to get the claws behind it, then use the slide hammer side to pop it out. .....i believe it takes like under 5 minutes
Old March 28th, 2015, 02:57 PM   #96
i believe you've never crashed into the sand. that **** gets EVERYWHERE. i remember having sand in my ass crack, between my toes, in my mouth. surprised i didn't pee sand afterward
Old March 28th, 2015, 03:00 PM   #97
I believe I started with that approach. I had a blind bearing puller that I broke. Couldn't get the initial space opened, so I pulled the seal, crushed the cage, and attempted to pull from the groove in the outer race. I believe that failed and broke my cheapo tool.
So I believed in beating the inner race on one side to take advantage of the radial bearing vs a thrust bearing to open it up. Then I kept pounding.
I believe I have won Bearing 1: chris 2
Old March 28th, 2015, 05:51 PM   #98
DSomething
DSomething's Avatar
I believe that sucks and could potentially require a de-sanding.
(Crap, I said it again)
D.
Old March 28th, 2015, 06:19 PM   #99
adouglas
adouglas's Avatar
I believe it's too late in the year to be snowing.
Again.
Old March 28th, 2015, 07:16 PM   #100
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I believe that old man winter is full of ****
I believe flipping the birdie at the sky while riding through it is the appropriate response to such nonsense
Old March 28th, 2015, 09:21 PM   #101
i believe... if the police are trying to pull you over, it means you weren't going fast enough.
Old March 28th, 2015, 11:18 PM   #102
corksil
Again, I believe that this man is onto something ^^^^
I believe that the cooling system of my truck has been adequately repaired enough to tow my excavator DOWN hills tomorrow, but I'll enlist the help of a friend to tow it UP them.
I believe that such is life living on the side of a volcano.
I believe that whoever invented radiator "stop leak" is the absolute filth of the universe and should be expunged and relegated into exile.
I believe that stop-leak in a cooling system is a bandaid on a broken leg.
Old March 29th, 2015, 12:21 AM   #103
i believe ... the best riders seek instruction ... and the not so great ones seek a ride with their instructors.
Old March 29th, 2015, 01:10 AM   #104
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
I believe...insurance rates for new drivers are going spike this coming weekend
The Bike | The Truck
Old March 29th, 2015, 04:17 AM   #105
adouglas
adouglas's Avatar
I believe that when the U.S.S. Nautilus (first nuclear-powered submarine) developed a leak in the condenser (non-radioactive) section of the reactor cooling system they put in to port in Seattle, put some enlisted men in civilian clothes, and sent them all over town on a "secret" mission to buy all the stop-leak they could find.
I believe they returned with 140 quarts of the stuff, it worked and they went on to traverse the North Pole submerged... something that had never been done before.
I believe this is a true story.
http://www.historylink.org/index.cfm...m&File_Id=3739
Old March 29th, 2015, 04:20 AM   #106
adouglas
adouglas's Avatar
I believe that women in leathers are hot.
I believe that how you choose to interpret that statement says more about your attitude than it does about the statement.
Old March 29th, 2015, 04:51 AM   #107
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I believe I would also be hot in leathers. And sweaty. And not hot to look at. Unless in perforated leathers, then I would be warm, perhaps cool. I do believe.
My Cafe Racer Build
My intro post
Old April 19th, 2015, 08:27 AM   #108
I believe... somewhere out there, is a very funny guy.
Old June 15th, 2015, 09:59 AM   #109
I believe… If ya gots more sponsor tattoos on ya skin than ya’s race suit… yins might be a true racer
I believe… Dat if ya close ya eyes and just listen during a race start, it be soundin’ like a sasquatch howlin’ contest
I believe… Dat ya could be savin’ another $10 spot on ya’s track day if yins tool box be havin’ a syphon hose in der
I believe… Ya’lls just might like motocycles too much if you consider MotoGP porn
I believe… Ya be needin’ a new group a friends to ride with if you say Sumo… and they thinkin' your talkin’ large Asian wrestlers
Old June 15th, 2015, 10:12 AM   #110
I believe... Dat da word "farkles" started out as a cute name for girls fartin' in der race suit
Old June 15th, 2015, 11:26 AM   #111
You ever drink too much at the track, pass out and wake up da next mornin' in the middle of swap meet? Ya know... they be auctioning off your bike and all but ya wake up just in time... lol
You know... If your a guy.... and you compare the riders wiggling out of their race suits to a magic mike movie, you just might be battin' for the other team. Ya know what I am sayin'. lol
Old June 15th, 2015, 11:39 AM   #112
adouglas
adouglas's Avatar
I believe that in between a week's worth of DVR recordings of the IOM TT, 25 uninterrupted hours of Le Mans coverage, and MotoGP in Catalunya, that I overdosed on racing last weekend.
I believe I still haven't watched Moto2 or Moto3.
Old June 15th, 2015, 11:44 AM   #113
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I believe every way to interpret that statement is correct
I believe I can understand everything guy martin says...after replaying it 4-5 times
Old June 15th, 2015, 11:48 AM   #114
I believe... That Guy Martin is actually a redneck. You can tell if you just understand every 4th word. Go ahead, try it. lol Boomhauer is his brother, I swear.
Old June 15th, 2015, 11:56 AM   #115
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Guy is from Lincolnshire...I believe he's as close as the brits get to being a redneck because of that
I believe that riding street is boring unless I'm riding with someone else now
Old June 15th, 2015, 02:16 PM   #116
ah's sponso'in' a yo'ng noo racer. ah sent him some stuff t'he'p him git race ready an' this hyar is th' email ah got back. Shet mah mouth!
Dear #511,
Mah name is Daryl an' ah's jest 5rys old fum KY. ah jest be hankerin' t'thank yo' fo' th' takeoffs, used oil filter an' scratch off lottery ticket. ah can’t figger out how t'install them on mah bike though, on account o' ah can’t git th' trainin' wheels off yet. Oh, mah possum chicken strips is huge still on account o' ah can’t lean, but mah Pappy says ah fall down inough already. But, ah's gittin' ready fo' mah next race an' all is fine so far but ah can’t pass tech due t'mah boots an' sueyt double as mah Elvis imvarmintashun outfit on account o' mah Maw is hooked on thet bedazzlin' stuff but th' sunglasses is right fine. Jest so yo' know, mah older brother crashed mah bike ridin' aroun' th' yard, cuss it all t' tarnation. It took us a fine hour t'find him on account o' Paw hasn’t mowed da grass th' last 2 summers. Hell fire, when we did find him, we had t'ax th' lawn jockey fo' direckshuns back t'th' house. But we gotter fixed up right quick an' got it loaded on th' trailer. When we loaded it, mah cousin noticed th' trailer had a flat, but Uncle Buck saved th' day by takin' one off th' house t'git us gwine on time. You know the trailer and the house are the same year and have the same axle and lug pattern.
Oh! Fry mah hide! Mah noo exhaest soun's awesome!! Fry mah hide!! Fry mah hide! ah had t'make a right mount though t'hold th' card on th' wheel spokes, but Maw says she be hankerin' th' wire clo'es hanger back at th' end of th' season, as enny fool kin plainly see. ah figger Paw will need it befor' then t'hold up th' muffler on th' tow truck. Shet mah mouth! Kerry of AreaP is wawkin' on a prototype, but kin’t git it t'pass th' soun' limit. In th' meantime, ah send mah Paw away fum th' soun' booth af'er he etts dem beans which seemed t'he'p git th' soun' wifin th' limit but he swars it’s th' race fuel an' burned rubber we smell, ah don’t knows about thet though.
ah jest wanted t'let yo' knows thet ah had a problem slippin' on th' seat mah last race but mah aunt knowed exackly whut t'do. She put scotch guard on it. She said it'd he'p in 2 ways; hold me on th' seat an' keep th' poop stains fum settin' in, as enny fool kin plainly see. ah told them, ah w'd use mah 3rd cousin’s velcro migit tostin' sueyt but they needed thet fo' th' han'icap rodeo next weekend, cuss it all t' tarnation.
An' one last thin'! Fry mah hide! Thet yeller banana holder yo' sent fum thet fancy unnerwears sto'e… mah Maw says it matches th' kitchen cabinets real fine.
Till next time…
Daryl
Old June 15th, 2015, 02:20 PM   #117
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I believe my head hurts from reading that
Old June 16th, 2015, 10:06 AM   #118
Old June 16th, 2015, 10:46 AM   #119
adouglas
adouglas's Avatar
I believe this was the only sentence in that post that I had a hard time understanding.
Old June 16th, 2015, 10:53 AM   #120
lol!!!! ask me if you need a translation, the only way you can get it is in person
