Old May 20th, 2015, 03:02 PM   #1
saber63
Motorcycle(s): '90 250 project, '03 250r, '14 STR,12 STR, '01 R6
I need to fit a 160 rear on....
For... reasons... (no really, i do need it, not just for looks) going with either a pilot power 2ct or a road3 ( or a track only tire)
Options are dropping in a 08+ rear wheel, however i thought these pinched the 160/60/17's and hurt cornering grip? (NOT AN OPTION!)
Or am i going to need a different swing arm? I recall a few that were close to drop in...
Once I have more of the project DONE, I'll let slip whats up
-Levi
saber63 is offline   Reply With Quote
Old May 20th, 2015, 03:17 PM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
you're on a 1990 250?
not happening on that swingarm or wheel, a 17" conversion on the 250 is tricky and pricey enough as it is so it's not really worth it to do. But if you're adamant, get a swingarm from a ninja 300 and a ninja 300 rear wheel, afaik that'll support a 160...barely
the '08-'12 rear wheel is smaller than the 300 wheel
Old May 20th, 2015, 03:20 PM   #3
Old May 20th, 2015, 03:22 PM   #4
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
A 160/60 fits fine on a 300 rear and with room to spare in the swing arm.
No clue how to get that on a pregen though. Good luck!
Raven's Rejuvenation
Old May 20th, 2015, 03:24 PM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
theory:
the newgen swingarm is direct bolt to pregen
the 300 swingarm is direct bolt to newgen (not 100% sure of this but I believe it is)
therefore the 300 swingarm is direct bolt to pregen
Old May 20th, 2015, 03:33 PM   #6
saber63
If the 300 is a direct bolt in, i would go that route. Anyone have any measurements?
I have a swing arm option on hand that is not a bolt in.... and would go with it over the 300, if cutting is involved.
Thanks!
-Levi
Old May 20th, 2015, 05:47 PM   #7
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Thanks!
-Levi
Check out my build below for an alternative.
My Cafe Racer Build
My intro post
Old May 21st, 2015, 02:14 AM   #8
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
check out the 250's in Indonesia..
The Bike | The Truck
Old May 21st, 2015, 07:50 AM   #9
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
From what I've seen, the NewGen and 300 swingarms are basically the same, with some minor accessory mounting differences. I have a 300 chainguard/hugger on a NewGen swingarm on my 500...
You'll want a 300 or aftermarket wheel for the extra width to put a bigger tire on. FYI, that's a Pilot Power 150/60 on a Vrossi wheel from overseas.
Old May 21st, 2015, 12:23 PM   #10
Panda
not an actual panda
150s get pinched on a 08 rim.
Old May 21st, 2015, 02:53 PM   #11
Baron
Urban Legend
Baron's Avatar
Motorcycle(s): 09 Ninja 250R SE - Circe
Now now, let's not go about giving anyone some crazy ideas.
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up."
-Baron
Baron is offline   Reply With Quote
Old May 21st, 2015, 03:27 PM   #12
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I say you get a stretched swing arm and be unique!
Riding it like I financed it.
Old May 21st, 2015, 03:31 PM   #13
the moto3 slicks are 120 width and will be much stickier than any dot tire.
why do you need a 160 width again? added rotation weight, larger contact patch with the same weight == less grip.... it seems like if you are trying to gain performance, you do not want to go with a +30 tire... but maybe i'm just dumb...
Old May 21st, 2015, 03:55 PM   #14
Cuz he likes how it looks and was upfront about it. I can respect that because he was upfront about it.
1 out of 2 members found this post helpful.
Old May 21st, 2015, 04:54 PM   #15
crazymadbastard
I do believe Levi believes he NEEDS it. I think he has a monster motor swap under wraps. I went wider and taller in the front because I like the look.
My Cafe Racer Build
My intro post
Old May 21st, 2015, 05:57 PM   #16
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Yes, you need a 4 inch rim for the 150.
Old May 21st, 2015, 06:09 PM   #17
Huh. Looks like a reading comprehension fail on my part. Oops.
Bro. You don't need it.
Old May 21st, 2015, 07:35 PM   #18
verboten1
verboten1's Avatar
MOTM - June '15
I have a ninja 650 wheel and a 250 swinger in you want to make them work together. $160 plus shipping
Ride more, worry less.
Old May 21st, 2015, 09:47 PM   #19
MrAtom
MOTM - July '15
Old May 22nd, 2015, 03:09 PM   #20
saber63
Cheers!
Someone nailed it! Sense it would appear that there are a bajillion options,and some very useful people, I will let slip the info, So people can provide more useful info!
The motor is a CRF450R with the 12v stator added for lights, and some motor work done. Should be in the 45-55hp range at 11K, but makes amazing torque down low. ~35ftlbs at 6K and 28ftlbs as low as 4K.
(The motor isn't mounted yet, but will fit, but still so much work to do, and so little time)
The extra torque is what has me concerned with grip at full lean. A big thumper is different than twin up in the revs... If i can get away with a 17" 250 rims and a diablo rosso II... I am so game for dropping weight! (These tires suck in the rain btw, had um on my STR)
I'm ALLLLLL ears on what would be the best tire choice for both dry street/track. And also wet commutes (this is proving hard).
I would be up for a Vrossi rims or similiar, IF i could find any...
Thanks guys!
Old May 22nd, 2015, 03:59 PM   #21
InvisiBill
InvisiBill's Avatar
Admittedly it's a twin, but those numbers are similar to the EX500.
The 500 comes with the same 130/70 as a NewGen.
Old May 22nd, 2015, 04:53 PM   #22
Yeah, you may appreciate a 150, but a 140 or 130 will be fine.
90's era 600's ran 160's or 150's iirc. They're putting down more than that in the torque department. Someone check me though, I may be wrong
Old May 22nd, 2015, 05:23 PM   #23
saber63
Interesting!
Pretty much all the super motoard guys run 150-170 rears (~165 ). They could lace up what ever rim they wanted, to run what ever tire they wanted....
Also Dunlop lists the ~160 size slicks for Super motard track use. and not the Moto3/125gp tires....
This is what started the question....
However I wonder if this is down to gearing? They usually run a 14/44 ish gearing for sumo racing.... So a lot more torque to the wheel!
I plan on running a 15/ 38-40 type gearing, should keep the motor from being to high strung on the freeway. (subject to change once testing)
Thanks!
Old May 22nd, 2015, 08:57 PM   #24
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I believe the DRZ400sm runs a 140 in the rear.
Old May 23rd, 2015, 02:56 AM   #25
Well I guess I should also add that the power delivery is different than the older 600's. They have less power "per bang" than the thumpers, and their bangs are more frequent.
So i'm not sure if that means you'd want more tire or less tire to give time between slipping and gripping (someone posted good info on that from the whole crossplane crank thing and from when tires went from bias to radial in MotoGP bikes. Good read)
I'd also hazard a guess that a lot of why sumo guys run big phat tires is because of the lookz, yo.
Old August 6th, 2015, 10:56 AM   #26
HoneyBadgerRy
HoneyBadgerRy's Avatar
"Locktite I put that **** on everything" That is so me, except in torque specs. I torque everything, I found a way to put a philips bit on my torque wrench just so I could torque the bolts that hold on my plastics on my old dirt bike. I torque on the brake mastercylinder cover, I torque everything.
Will a 160 Tire fit on Stock Rear? ejlover 2008 - 2012 Ninja 250R Tech Talk 17 April 22nd, 2018 11:07 AM
[hell for leather] - For $160, all the helmet you’ll ever need Ninjette Newsbot Motorcycling News 0 May 21st, 2012 05:20 PM
Go pro hd on eBay for 160? Klondike1020 Motorcycle-related 13 February 25th, 2012 11:03 AM
160 gig ps3 NoobNinja Miscellaneous 7 November 15th, 2009 09:59 AM
what should I get with $160. tinng321 General Motorcycling Discussion 18 May 29th, 2009 05:51 AM
