Old December 6th, 2014, 09:08 AM   #401
Gurk
Done here.
Motorcycle(s): -
I hit refresh like 10 times...
I quoted the post to make sure...
But still, your post seems to be missing the pic of the bike that goes along with all this dirt gear.
Hahah That's happening in January
Gurk is offline   Reply With Quote
Old December 6th, 2014, 09:10 AM   #402
Gurk
Done here.
Motorcycle(s): -
Originally Posted by psych0hans View Post
What was the damage on all this gear?
I try not to add them up and find out. Better this way
Old December 6th, 2014, 09:10 AM   #403
Old December 7th, 2014, 08:56 PM   #404
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
Man thats some fine dirt gear!
"That's what" -she
Roark is offline   Reply With Quote
Old December 8th, 2014, 04:19 PM   #405
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Its an R6bro. Yammies love the dirt.
No limits @csmith12
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old December 8th, 2014, 04:21 PM   #406
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
reminds me of the dirt panigale
I love supersports re-purposed for dirt use, it just screams "I like sliding the rear out"
Old December 16th, 2014, 07:54 AM   #407
Bought a couple of these things. to help with my second HID installation and promptly discovered that you can't plug them together. Well, you can, but they will lock together and not come apart without breaking. They will plug and unplug the Kawasaki parts just fine, but there is a tab in female part locks into hole in male part. The least they could have done was make the tab face the other way.
If you only lock one blade then you can manipulate it out without breaking anything, but if you lock both blades in a rigid connector you will likely break the ceramic to get them apart (one of mine broke and the other didn't). The edge holding in one female connector broke, freeing the connector, which allowed me to manipulate the other blade out without breaking it.
Luckily, I only needed the male side to splice into my HID kit, but it looked like I actually could fix the broken-loose female connector by ejecting the other connector and putting them into the ceramic upside-down (looked identical). The boot would then cover the broken side. I was ready to just shatter the ceramic and save them for future use as loose connectors when I noticed that.
Stupid design, but works for what I need it for.
File Type: jpg $(KGrHqVHJEwFFy,lgeEwBRdf,l5j-!~~60_12.JPG (38.3 KB, 0 views)
Old January 12th, 2015, 02:27 PM   #408
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
RS Taichi RST604 e-Heat Protection Glove. I cannot wait to test these out.
Last futzed with by antiant; February 9th, 2015 at 04:18 PM.
antiant is offline   Reply With Quote
Old January 12th, 2015, 03:25 PM   #409
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Going to try these:
http://voltheat.com/product/volt-3v-heated-socks/
They are the only ones I've found with an expanded battery pack. If correct and the socks do live up to the claim, they are the only ones that have the power to last during an all night ride - on low, they almost last for an entire day!
Approximate Battery Run Times for VB320 /3.7v 2000mAh batteries (included)
100% Highest Setting = 3+ hours
75% Medium/High = 4.5 hours
50% Medium/Low = 6 hours
25% Low = 10 hours
Approximate Battery Run Times for VB50 /3.7v 5000mAh batteries (optional)
100% Highest Setting = 8+ hours
75% Medium/High = 12 hours
50% Medium/Low = 16 hours
25% Low = 20+ hours
<-- Linky
Old January 18th, 2015, 06:44 PM   #410
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I know it's not gear, but I didn't feel like starting a new thread. Today I got a new tool cabinet to replace my old one.
The new cabinet is the Husky 46 in. from Home Depot.
It's replacing my old roller cart from Harbor Freight.
I got a lot of use out of that four drawer cart, but I was in need of something with more storage space. I considered the 44 in. roller cabinet from HF, however for $100 less I decided to get the Husky one instead. It does have less drawers and a lower weight capacity than the one from HF, but it should be fine for my use. I also think the wood top is a nice touch, and I prefer the black finish over red. For the price I think it's a pretty good deal.
Old January 19th, 2015, 12:13 AM   #411
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
Nice box Munky
Got my second bonus ever just after Christmas. I got myself a belated present.
A set of Gerbing EX heated gloves. Can't wait for the fog to clear so that I can test them out.
My commute is going to be awesome with heated liner and gloves!
iamjacob is offline   Reply With Quote
Old January 19th, 2015, 11:47 AM   #412
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
BurnsMoto USB 2.1 Dual Port Panel Mount.
Old January 19th, 2015, 02:04 PM   #413
NevadaWolf
NevadaWolf's Avatar
Like the wings I made, but they take too long to install/remove so trying something cheap
<-- Linky
Old January 19th, 2015, 02:16 PM   #414
iamjacob
iamjacob's Avatar
Any pics of them while you had them installed? I'm guessing that you used these as hand guards?
Old January 19th, 2015, 02:33 PM   #415
NevadaWolf
NevadaWolf's Avatar
Those are the knockoff Acerbis dual road handguards I just ordered. Replacing my winter wings with those when they come in so will take pics of them installed.
<-- Linky
Old January 19th, 2015, 07:47 PM   #416
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Got me some tools. I got tired of making due with mixed matched sets. Tooltopia has excellent prices. The baby air ratchet is pretty badass by Florida Pneumatic. Can torque to 25lbs. Has 2 slides to switch direction. Home depot has best pricing on that and is made in Japan.
My Cafe Racer Build
My intro post
Old January 19th, 2015, 07:55 PM   #417
Chrit
Chrit's Avatar
Motorcycle(s): Ninja 250R 2012
Got myself a hugger!
Chrit is offline   Reply With Quote
Old January 20th, 2015, 05:57 AM   #418
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Just got the "Transitions" pinlock insert i had to order for the UK. Seems it will work well. Just waiting to get the clear pinlock shield from Revzilla.
Raven's Rejuvenation
Old January 20th, 2015, 08:34 AM   #419
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Interested in pics of this in and out of the sunlight please. I hate to change visors
Old January 20th, 2015, 08:43 AM   #420
LittleRedNinjette
Sure, i'll post them up as soon as the shield comes in. When i had it outside it looked like it got to a nice shade.
I hate changing them too. And they take up valuable bag space.
This is the one i got: http://www.ebay.com/itm/321550625456...%3AMEBIDX%3AIT
Old January 22nd, 2015, 05:01 AM   #421
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Jason5885 is offline   Reply With Quote
Old January 28th, 2015, 02:40 PM   #422
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Powerlet Type-1 Rearset Kit. Now, I just need a heated jacket liner and I won't be shivering in the cold or rain.
Old February 3rd, 2015, 08:13 PM   #423
crazymadbastard
lithium goodness, got it for mounting possibilities. Shedding the stock plastics and need to have more mounting options, got it from amazon for $70.
My Cafe Racer Build
My intro post
Old February 3rd, 2015, 08:18 PM   #424
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Got me some dunlop rains, 2 rears and a front for a real good deal. I've been liking my Q3s quite a bit and I like dunlop as a brand so I get the feeling I'll be running dunlops on my gsxr for the upcoming race season. Now to get some extra wheels to mount them on so it's easy to swap when the time comes.
pic isn't of the ones I got which are slightly used (front has more wear than both of the rears )
Old February 3rd, 2015, 09:33 PM   #425
Roark
Roark's Avatar
What bike are these tires for?
"That's what" -she
Old February 4th, 2015, 05:38 AM   #426
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Completely covered now! lol
The Bike | The Truck
Last futzed with by Singh2jz; February 4th, 2015 at 03:20 PM.
Old February 4th, 2015, 07:13 AM   #427
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
track gsxr 600, I'll be getting some rains for the track 250 down the line as well
Old February 4th, 2015, 09:04 AM   #428
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Teri, any update?
I'm interested in finding out if the pinlock you got turns that purplish hue that older photochromic glasses have. Not a fan of that... I prefer straight neutral gray.
Old February 4th, 2015, 09:11 AM   #429
LittleRedNinjette
The pinlock shield should be here tomorrow. I wanted to get the pictures with the insert in the shield for the most accurate color, but i will say it seemed to stay in the gray smoke range.
Now lets hope its sunny on Saturday...
Old February 4th, 2015, 10:10 AM   #430
Roark
Roark's Avatar
What tires will you be getting then? For the pregen, I assume
"That's what" -she
Old February 4th, 2015, 10:25 AM   #431
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Once I have the budget together for parts I'm switching to a newgen front end and swingarm for the 17" tires
pirelli drII for dry and some dunlop 125cc race rains for the wet if i don't find any better rains
http://stores.racetireservice.com/DU...AIN-SET-125CC/
I'm also looking into getting some bodywork for the bike though I may end up just making my own with the multiple sets of broken 250 fairings that I have already
As much as I enjoyed riding the gixxer last weekend the 250 is every bit as fun and puts a lot less force on the body under braking and accelerating. Ideally I'll turn my 250 into a track weapon that's every bit as good as a newgen race bike so I can race both bikes in the future
Old February 4th, 2015, 08:24 PM   #432
shereth
shereth's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250
Been a little busy this week.
Because I'm fond of my spine:
New toys for the bike!
Everyone needs new shoes before they go run at the track:
shereth is offline   Reply With Quote
Old February 8th, 2015, 09:30 AM   #433
LittleRedNinjette
Ok, best I could get with the lack of sun. It has an odd hue in the pick but it didn't look that bad in real life. I think it'll be darker when better sun. Be able to give a better review when I can get back on the bike.
Old February 8th, 2015, 04:37 PM   #434
sharky nrk
sharky nrk's Avatar
Attachment 34797
I think I want one now lol
Old February 8th, 2015, 04:41 PM   #435
sharky nrk
sharky nrk's Avatar
I really like my pair of LatigoRRs
Old February 8th, 2015, 05:23 PM   #436
cuong-nutz
cuong-nutz's Avatar
Too lazy to install my new fork springs.
HalfFast Racing Team
Old February 8th, 2015, 06:10 PM   #437
LittleRedNinjette
Next warm day I'll make my boyfriend help me get the bike out so I can send how it is in full sun.
Old February 9th, 2015, 12:37 PM   #438
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Michelin Pilot Street Radials. Finally.
Old February 10th, 2015, 11:03 AM   #439
Roark
Roark's Avatar
@Singh2jz, you wearing those RRs in the winter??
I've got the WP pair, and they're comfier than my friend's pair of SMX-5's!
"That's what" -she
Old February 10th, 2015, 11:20 AM   #440
iamjacob
iamjacob's Avatar
I've been wearing mine all winter. My feet only get cold when it dips into the 30s.
Post pics of your most recent track/racing BP (Body Positioning) Nemesis Ninjettes At Speed 1183 November 24th, 2022 04:59 PM
Why all the pop ups HKr1 Forum Information 8 October 8th, 2014 02:20 PM
what's your pick? LoneRonin Motorcycle Gear 16 April 2nd, 2014 10:49 PM
Which Would You Pick? tnr4 General Motorcycling Discussion 31 August 22nd, 2013 06:44 PM
post your most recent purchase burningscooter Off-Topic 10 March 28th, 2012 04:10 AM
